Crank sensor cause single cylinder misfire?
O5berylgrnrenegade
Canada
So i ended up getting a p0302 code this week coil on cylinder 2 was weak and replaced it 3 days later it returned followed by p0016 can a bad crank sensor cause a single cylinder misfire? Plugs are good as is compression
KJ05user
Hi, did you find the reason for the p0302 code. If so what did you do to fix it?
