FCSSensai
- Joined
- Oct 19, 2023
- Messages
- 14
- Reaction score
- 0
2005 3.7L Liberty w/ ~180,000 Miles
Here are the codes:
[Key: RED = Current, GREEN = Resolved By Diag]
P0300 - Multiple Cylinder Misfire, this may come back due to the lower two codes, but the instant flash of it is gone I suspect due to the fouled looking spark plugs being changed...
P0204 - Fuel Injector 4 Circuit/Open
P2317 - Ignition Coil 6 Secondary Circuit - Low Ionization
Here are the symptoms:
Rough Idle
Will not rev past 2100/2200 RPM
Past 2200 RPM, the car needle "dances" up and down
Upon listening to injectors, some are clicking rapidly, some are slow and clacky. It's really hard to tell, but I'm assuming it may not be the injector itself given I've cleaned them and ran cleaner. I may replace these if suggested...
Here are my thoughts:
Initially, based on this post: https://www.jeepkj.com/threads/misfire-from-injector-wiring-circuit.69585/ I thought it may have been a wiring issue.
I therefor checked a lot of wires, and don't see any issues.
I may check voltage here soon, unsure on if that's at all helpful.
I feel like a shorted wire would be more obvious, and cause a lot more than two cylinders to basically go down the drain.
Here are steps I have taken to diag/fix this:
Battery Terminal Disconnect for 24 hrs to "relearn" (Done Twice, no help.)
Checked Fuses (All related fuses move power and don't appear burnt)
Swapped Coils 6 and 1 to rule out the coil 6 (Problem persists in cylinder 6)
Cleaned all 6 injectors (Beginning to suspect I should order new injectors...)
Cleaned entire fuel system and switched to Shell 93 for a full tank of driving (No help, just as the injector cleaning)
Inspected wires to/from coil 6, injector 4, and PCM (No damage apparent? Moving the wires did nothing as well, which I believe would not be the case if it was shorting out.)
Swapped Relay for ASD with Lower Rad Fan (No change, rules out ASD Relay Failure)
Pulled, Inspected, and cleaned up all PCM plugs (Ideally hoping the PCM itself isn't going bad, although as many have mentioned on here, that would come with more signs than just a coil 6 low ionization.)
New Fuel Filter
Cleaned Throttle Body
Possible Solutions:
Compression Test #2 will be completed in the next day or two
Will likely buy a new set of injectors if it passes.
Hoping someone like @Billwill could help?
Here are the codes:
Rough Idle
New Fuel Filter
Possible Solutions:
