Andynator
It was pretty cold yesterday morning when I was heading to work - 15°F. Not brutal, but cold enough to let my '02 warm up for 5-10 minutes before I headed out. When I pulled out of the driveway, my check engine light came on. I could feel the transmission slipping very slightly when pulling away from the first two stop signs, but it acted normally otherwise and it quit slipping as it warmed up.
Last night when I checked the error code, it threw back P0700 - the generic transmission code. Fluid is fine and clean. Can't get it to slip now that is around 35°, shifts normally.
How long should I wait to see if the code clears itself or decide if it needs to go into the shop?
Thanks,
Thanks,
