AlexKJ
29'' tall tires and 3.73:1 gears is one combination you found from factory... I assume that is a correct combination for both power and fuel economy...
As for an example, this combination throws 67mph at 2000rpm, considering 2WD position in the transfer (1:1) and the O/D of the 42RLE engaged (0.69:1).
I've always read here that you have to regear to 4.10 if you go for a 245/75R16 (OD: 30.5-30.7), but with these tires and 4.10, at 2000rpm you'll go slower: 64mph
Yeah, sure... 4.10 gears and 31'' tires certainly gives you more power off-road... but, as I see it, If you regear to 4:10 with 245/75R16 tires you'll end out of factory spec as well...
So... What tire's size need I to have for going back to factory spec after a 4.10 regear?
According mi calculations is an OD of 31.7, which is close to a 265/75R16...
What I get is that you *have* to regear a 4:10 with 32'' tires to go back to factory specs... but you have to make a compromise if you go for 31''... City economy and increased off-road performance (4.10) vs highway economy (3.73) maybe... Idk...
What do you think?
What do you think?
