2012 Liberty oil leak
frankjc
Have a leak on the front passenger side of the engine. I took a couple of quick pics, didn't have much time to look at it. Have to clean it up a bit too. Anything common in that area that I should look for? Also appears that the sending unit above the oil filter is leaking. Could it be making its way over to the other side of the engine?
Often a leak from above oil filter = an oil pressure senor.
Cleaning it up will make it easier to tell where it is coming from.
Best-o luck.
frankjc
i am planning on replacing the most obvious part, which is the sender, cleaning it off, and seeing what happens.
