2012 KK Lift Medium Springs for Rear
sparky27
Michigan
I am getting ready to do an OME lift in my 2012 KK. I previously had the HD lift done on my 2006 KJ. This time around I am considering doing the Medium springs for a slightly softer ride. Which rear springs are the medium duty for a KK Liberty?
So far I have
OME 2926 for front springs
OME 90009 front coilovers
OME N132L Rear Shocks
What would I use for the rear spring if I want to go Mediums front and back (instead of the 731 rear spring)?
Any help is greatly appreciated.
There NEVER was a Heavy Duty rear spring from OME for the KJ or KK
Not sure what you had but only mediums and light duty
for the KK 2730 is light duty
and medium is 2731
And you are using 132Ls with wanting a light duty spring ??
132Ls were for higher lifts than what you will need ,
Do you have the Tearflex front bump stops and rear hockey pucks for bumpstops figured in ?
sparky27
Michigan
I went through my old posts and saw I actually did buy the medium duty for my kj before and not the hd. So I will go with medium again (2731).
As for the n132l, I thought that was what I needed for the lift. I see now that it is not. So I should get N132 instead.
Here is my updated list for a 1.75”-2” lift.
OME 2926 Front springs
OME 90009 Front coilovers
OME N132 Rear Shocks
OME 2731 Rear springs
4 hockey pucks w 2.25” bolts, nuts n washer.
2 Tera flex bump stops
S
since you NOW are going with the 731s in the rear which gives more height you can use the 132Ls
with the 926s it will have a rake front to rear
