2006 Jeep Liberty 3.7
Brawkzlit
Hey guys really searching for some help, the other day I started my KJ, and it had this loud ticking noise when I was to accelerate it was get faster. Anyway I changed oil and added lucus oil to too make it thicker, well there is still a tick and Just lookin gun for some advice, I’m pretty mechanically inclines so just looking for some help.
Welcome.
Sounds like an engine ticking noise, valve train tick .??
A mechanical stethoscope may help to pinpoint left or right side etc.
May have to pull valve cover (s)
to inspect rockers, or one loose ?
You could pull the accessory serpentine belt for a few moments, to eliminate accessory noises.
Brawkzlit
Yeah I also used at stethoscope, and found out it’s on the passenger side, only 128000 on it. I checked to see if it was an exhaust leak but puttin In the new oil kinda proved that. If I pull the vale cover off how would I be able pinpoint what’s bad
Making oil thicker will not help and many times make it worse
If you pull the cover you should be able to tell if a rocker is loose or getting ready to fall off
Brawkzlit
Oops lol. Being that they’re hydraulic lifter I thought maybe if the was a weak lift it would keep it from Ticken like it was. Alright I’ll give it a look here a let you know what’s up, Bronson gym my fingers it’s not a crank bearing or something down there lol
jeeper03
warrenton Va
I would change all the lifters in it. Honestly not that bad of a job if you have the tools and I’ve seen to many fail right around 100k. Don’t end up like this guy, just put a new engine in his at work last week.
Brawkzlit
Yeah I’m going to see, and replace the gaskets and stuff. It kinda stops ticking when she get warmed up. Thanks for the advice guys!
Have a customers 05 that has a slight tick in it till it warms up. At 25-30 degrees it does it for about 5 minutes or less
He is of the type if its still running don't touch it LOL
Love to get in there now and replace rockers/lifters esp since I have a set sitting in the shop
Shane Giggie
My 06 ticks a little too until it gets warmed up then its perfect. Mine has 240,000kms not sure what that is in miles.
Yeah, that's about 150k. That's about when I had a few weak ones in my 02. Actually had the #2 exhaust fall of twice. The second time I replaced several of the lifter/lash adjuster on that side and no more problems.
Brawkzlit
The next day it had a loud tick, changed oil tick gone when warms up. I’m having someone diagnose it Monday, then I’m going to fix it
Brawkzlit
I just wanna make sure Ik what it is before I tear it apart, if it’s like a cam bearing then I’m goin to probably have to get some stuff Cause I don’t have cherry pick or engine stand
