2002 coil pack connector
rigid
united states
Can anyone help with a part number or source for the pigtail connector to the coil pack? Apparently a mouse liked the insulation and shredded one of mine. The local parts store says this is a 45$ part. Mine is a 2 wire connector on a 3.7
Thank you for your help
rigid
united states
This is what it is.
DadOSix
Cumberland, MD.
local parts yard.
don’t limit yourself to just jeeps. most any mopar product of the samed age uses this connector.
i got a handful from a durango a few years back.
also - since your plug does not seem damaged, you can release the pins from the connector and solder a length of same gauge wire to the pin and make a nice repair further back the harness.
it uses a little paper clip sized pin into the square hole to release the pin.
cheap and simple if you or a buddy can solder.
and do not use plumbing solder. electronic 70/30 rosin core or similar is fine. the flux in plumbing solder does not play well in electrical connections
Boueux
Active Member
