2.4L valve cover r&r.
ElCheapo
Erie PA
I have motor oil in the air box, and seriously worn spark plugs.
Since I need to remove the TB to change the plugs, I'm also going to remove the valve cover, clean the internal baffles (see, I've done research!:bleh:) replace the PCV valve, clean the PCV hose, and replace the hoses as needed.
Is there anything else I should check/replace while the top of the engine is accessible?
I will take pics for the next guy, and post them.
ElCheapo
Erie PA
Changed plugs, didn't remove valve cover. It looks like I will need to remove the intake to do it, need to research more.
