05 KJ Cig Lighter Plug
eddiev9
Fairfax, VA
Has anyone modified the cig plug of an 05 to activate with the key ignition?
eddiev9
Fairfax, VA
It's just a precaution. There's a lot of interesting cig-plug devices here that I'd like to try out (that don't need to be permanently wired). The locals never have to worry since all their cig-plugs are activated by ignition; therefore, the devices are designed that way. I'm afraid one of these days I may accidentally leave something plugged in and it would drain my battery out.
Se7enLC
Watertown, MA
I have a GPS unit wired into a cigarette lighter, and it just stays on all the time. Left it be for a week or so, never had a problem.
I think the easiest way to get what you want to do is put an add-a-fuse into a circuit that is on with ignition (headlights, radio, etc). If the power draw is low, you're fine. If it's not, you'll want to relay the power from the battery anyway, but using the ignition as the power for the switch side of the relay will force it to turn off with the ignition is off.
cowcatcher
Spokane, WA
You could build your own adapter with an on off switch or install a second lighter that is wired to the ignition too.
billforde
Seaford, NY, USA
What you can also do is cut the positive cig wire, and connect in a relay, then use the ignition line from the radio to trigger the relay.
eddiev9
Fairfax, VA
That's sort of what I had in mind. Either that or cowcatcher's suggestion for an additional plug.
Can you tell me which color wire the ignition line is? I haven't opened up the HU area since last year...can't remember.
Thanks.
billforde
Seaford, NY, USA
In my 04 its the Orange/Red wire. The color in the 05 maybe different, but the location is still pin 2.
eddiev9
Fairfax, VA
Ahh! #-o Forgot all about that diagram. I got that from you almost a year ago.
I'm sure the wire colors are the same...but pin 2...got it! Thanks, bill!
