Rear Door Glass Removal
(1) Remove the waterdam. (Refer to 23 - BODY/
DOORS - REAR/WATERDAM - REMOVAL)
(2) Raise the glass and line up the lift plate clip
with the hole in the door panel shown. (Fig. 3)
(3) Using a long flat blade or hook type tool, disengage
the clip attaching glass retainer to regulator
lift plate.
(4) Disconnect the glass from the regulator lift
plate and re-install the clip.
(5) Position the glass into the bottom of the door.
(6) Remove the glass division bar bolt. (Fig. 4)
(7) Twist the division bar towards the inside of the
door and disengage the door glass.
(8) Remove the glass from the window opening.
Rear Door Glass INSTALLATION
(1) Install the glass through the window opening.
(2) Position the front of the glass into the glass
run channel and as low as possible in the door.
(3) Twist the glass division bar towards the inside
of the door and position the door glass into the rear
run channel.
(4) Seat the division bar firmly up and into the
fixed door glass, making sure the seal is well
engaged into the door frame with no gap inside the
car and no folded lip on the c-pillar.
(5) Lift glass up in the window and engage the pin
into the regulator lift plate.
(6) Raise the glass into the closed position and
install the division bar bolt.
(7) Tighten the bolt to 9 N•m (80 in. lbs.).
(8) Install the waterdam. (Refer to 23 - BODY/
DOORS - REAR/WATERDAM - INSTALLATION) DOOR GLASS
REMOVAL
That is a quick copy from my factory repair manual. I copied it from the pdf of course, sorry it did not get the drawings as well. I can attempt to print and scan those and try to get it on here if need be.
Hope this helps, likely you will be able to figure it out from this. These instructions are for replacing the rear window glass that operates up and down via the power window regulator. The fixed window in the door behind the moving window is similar, but even simpler.
Good Luck!
