Water Pump
krisP
NY/PA
recently replaced with a gates wp from napa. working well
I put a Napa reman one in mine. 50k miles on it, seems fine, knock on wood!
CzarKJ
Townsend, MA
Ok thanks! For the T-stat mopar? I did my hoses last year with my rad so those I will keep. Should have just overhauled it all at once but it again was winter and cold haha
mopar for t-stat.
gaskets w/ the t-stats don't come with a key for registration with the t-stat housing.
If you want that, felpro t-stat gasket from your LAP would have a key.
Yes the Mopar has air bleed hole (brass thing at 12 o'clock) 6817 4083 AA part #
The black outer ring is the gasket... so nothing else needed.
57884[/ATTACH]"]
Use HOAT coolant or Zerex G05 (reminder)
