Vibration
Ray A
New to the site. Have 06 Liberty about 4 yrs now. Daughter owned it 6 yrs before me and she drove it like she thought it was a tank. I've replaced most of the front end. I occasionally get a strong vibration I feel in the steering wheel and brake pedal on the highway. If I pull over to the shoulder and stop hard, take off again it stops. Anyone have a thought on that?
Welcome to the forum. Sounds like a warped front brake rotor or a sticking caliper.
Shops can easily tell by using a run out dial indicator.
Could be slide pins too...I’m replacing the caliper bracket for that issue. Rather would try that first than have to get a reman caliper!
Ray A
It does it only occasionally. Can't feel it until over 60ish mph. Then braking hard to a stop makes it go away.
Does it only happen if you’re braking? Is the torque converter locking up (RPMs dropping) as it happens?
Ray A
When the vibration happens it feels strongest in the steering wheel. Can actually see it. It's just strange how I can pull over, brake hard to a stop, then take off again and it goes away. A mechanic friend said it could ''possibly'' be a bearing race slipping out of place and seating back in after the hard breaking. I'm stumped. Don't want to spend for a repair then find out it wasn't the problem.
JasonJ
Michigan
If hard braking resolves it temporarily, it seems to me that something is shifting out of place for sure... but more likely a control arm/bushing issue, or perhaps an axle mount, or brake caliper mounting problem.
Has anyone actually gotten under it to inspect it, visually? Put hands on the bearing/hub assembly and checked for play? Looked for signs of worn control arm bushings, front/rear and top/bottom?
Make sure your caliper bolts and caliper bracket bolts are tight too.
