Vibration in snow
seadog-68
Canada
Hey everyone
Been having a strange vibration from the rear end when in snow.
It only happens right around 70'kph. In kinda shutters for a second or two and goes away.
It happens if you are in pt or ft 4wd.
It also happened when I had the front driveshaft out.
In addition you can sometimes hear a click from the back.
Kind of like the click you hear when a Cv joint is going.
Am I right to suspect that the LSD in the rear may be at fault?
Not to sure If it is a binding issue.
The shudder goes away after a second or two.
The fact it happens when the front de is out has me puzzled
osufans
Central Ohio
Just cause this it what everyone else tells me....have you checked your u-joints? After driving for a while, park the Jeep and touch the u-joint to see if it's hot. Just to give you a baseline...mine weren't even warm.
