Tow Lights
funnnyfarm
Kennewick,Washington
I have a 2005 liberty , and tow it with my motorhome. is there a way to wire in a connection from the motorhome to use the liberty tail lights ? thank you funnnyfarm
LibertyFever
New Brunswick, Canada
You probably can't do it easily. I suggest you get a magnet mount tail light kit from your RV dealership and stick them to the roof.
How are you towing the Libby? a wheel dolly? What is the Libby? 2WD or 4WD?
Ohio-white-kj
ohio
I have an 05 that the former owner used as a toad. It had a 4 wire trailer harness ran from the grill to the tail lights, they then drilled an appropriate size hole in the lower part of the tail light and snapped a 1157 bulb socket into it.
The harness is still in it, but I pulled the extra sockets out and taped over the holes.
Since the Kj seems to be one of the most used toads, I'm sure there are some sites detailing it - or a good trailer RV shop. I took the toad tow bracket off and googled some info for that and seem to remember seeing some info on lights then.
mag03kj
LOST
Get on LOST and pm jimymc. He tows his KJ behind a RV, he should be able to tell you want you need!
funnnyfarm
Tow Lites
Thats what I did ,Went to RV outfit and bought a Universal Wiring Kit from Roadmaster with the heavy duty diodes. It's a lot of work poping all the plastic covers down the in side to run the wires. But it's worth it.:D funnnyfarm
