Tow hooks
JMSMN
Hopkins, MN
I am not sure, but if they dont, i would gladly buy them for my 06' sport.
I am sure they will fit as I believe they are the same for 02-07 KJ. You will need to get the U bolts with them as they might be hard to find seperately. They are made with one shorter side so they can be put up into the boxed frame easier and then the hooks bolt up to them. That's how mine were anyway. I am referring to the OEM ones.
ChiefRudy
Pittston, Pa
Yes this will fit. When I bought my front tow hooks the instructions that came with them where for liberty's with the 02-04 front ends. I have an 2006. Just like Dave said above. You will need the U bolts for them. ( It's actually shaped like an M) The Bolt is meant for tow hooks being installed after the KJ left the factory. B/c to use regular straight bolts you need to remove the bumper.
