Replaceing interior lights with LEDS
dude1116
Pompton Plains, NJ
ok thanks, my cousin is good with wires so i will have him help me out since ive never wired anything before, if i do it ill manage to blow up the battery or blow every bulb in the truck :bleh:
You could leave the stock plugs and put in a bulb from the stealership or some equivilant. Only problem is that I don't know what bulb that is. I have LED strips hard-wired in.
dude1116
Pompton Plains, NJ
Hey guys I got mine off Amazon and they work great.
42mm Canbus LED Bulbs Pair White 6000k 576 578 211-2 212-2 214-2 Festoon : Amazon.com : Automotive
those work for the cargo area (1 light), back seat (1 light), and front map lights (2 lights).
all in all you're looking at two orders. These are really bright and easy to install.
WHITE LED Bulbs High Power T10 Reverse Backup Lights (A Pair) 147 152 158 159 161 168 184 192 193 194 901 904 912 916 917 918 920 921 922 923 926 927 2821 2825 w5w : Amazon.com : Automotive
these work for the front footwells
don't know if you guys are still looking for these parts but here ya go!
Hey man - how did you install these in the front reading lamps? They seem to be regular bulbs. Unless they're different for an '04 sport?
dude1116
Pompton Plains, NJ
OK so I think I figured it out. If I had an EVIC, then the bulbs would have been the same as the rear cargo area? I can't find any reference on the lightbulb for the map lights that i have. All I can find is that it's SUPPOSED to be 578, and the "ash tray light" is a 161 bulb (I don't even know where the heck that bulb is!) I pulled the bulb and it says 192H. Can someone confirm that's what I need? >.>
Every site I find says it should be 578. :( I'd actually rather it be a 578. Are there different housings for these things?
