Proper Wheel Backspace
robslibby
Does anyone know the proper whell backspace to order for 15 inch rims I see people using 4.5 and 4.75 but both seem to rub. Any help would be great.
robslibby
I was thinking 30 or 31's because I wanted to have enough room for wheel articulation
CRD4Liberty
Milwaukie, OR
As clse to 5 inches as you can get. Stock is 5 1/2 inches, but than you have a lot of interior rubbing. The 10.50 width is also part of the problem, it's pusshing the limits of space. You'll have to trim the front some and bend over the rear tab in the front.
My 16x8 rims with 5" BS work great with my 245/70/16 tires(VERY little rubbing). They are basically a 30" tire(29.5). O:)
CDKJ
265/70/16 & the best size rim???
Hey, my first post on Jeep KJ Country:)
I've got a set of Cooper STT 265/70/16 on my stock alloy rims & want/need to change the rim. I only wish to move it out about 5 to 10mm & am not sure what that means as far as back spacing go's. I've seen a lot about MOAB's & American racing rims but am not sure if they are exported to OZ or not. If not what should I look for, I don't want to go too far out as I still plan to take it off road.:D
So what do you think?, web links etc would be a help.
pr0zak8
Quebec city
on my kj i have stock option 17''x7'' wheels i dont know the back spacing of them and dont know how to find it either . i just bought the 3'' rough country suspension and 265/70r17 mickey thompson MTZ's (about like 31.5'') should i use wheel spacers to correct the 4.25 mostlly suggested BS ? i know ill have trimming to do because there will be rubbing but to limit the rubbing what can i do if i want to keep my wheels ?
