power door locks lock but will not unlock
teckman02
trotwood ohio
ok on the liberty if i go to unlock the doors with my remote or the dook lock button on the doors the doors will lock but not unlock. the only doors that WILL lock and unlock the way they should are the drivers door and the back cargo door i have also checked all of my settings on my EVIC
Paul M
Virginia Dale, Colorado
Do you have a factory alarm/security system? Might be connected to some weird setting with that - the driver's door and rear hatch are controlled separately when security is "on", but check your owners manual for the actual text. Otherwise try a hard reset by disconnecting the battery for fifteen minutes..see if that does it.
That's wierd. Sounds like it reset the lock/unlock options. Did you try your spare key/remote? Maybe the battery in the remote is weak? Hoping for simple things I guess.
