Geez... I can't remember what I paid for my EVIC from LKQ, but it darn sure wasn't $101... $25? maybe.Gris said:more so than Older/newer it's about what it does.
An OTIS is a display only model. an EVIC can actually control the computer to set various option.
I just recently got my EVIC from an '02 Chrysler 300M from LKQ on eBay for $101
the_titan said:Then in addition to that you need the wire and harness. Now all the ones I am seeing have the wire cut off at 6 inches or so. Is THAT where I am supposed to thread a floppy drive power harness? I thought that if you were lucky enough to get a full pigtail, there was a connector on the end that went up under the headliner. Otherwise you would need to solder an extension and run it down the A-Pillar and solder into your wiring. Is anyone getting away with not having to splice into this?
Someone please decipher, por favor
edit: This bracket thing
