oil pump
bitts
Texas
Can any one verify this oil pump and adapter?
I'm actually looking for one asap, used/new doesn't matter.
I can't find the adapter any where.
I plan on using it on my 2.4 that isn't in a jeep.
Thanks.
JeepCoMJ
SE WI
You realize that the oil pump is inside the engine, and you are asking us to verify something we can't see?
If you mean oil filter and adapter, then someone can step up.
CactusJacked
Chicago Suburbs
Oil pump is not inside the engine. That aluminum housing that the filter/adapter is bolted to is the oil pump. The one part of it that's inside the engine that you can't see is the pick up tube to the pan. Have you tried checking with the dealer yet?
