oil pressure gauge
Kruzn
Central Illinois
I'm planning on adding an aftermarket (VDO) oil pressure gauge to our '06 Libby.
Are the oil pressure switch threads on the 3.7 metric, or normal 1/8" NPT?
Is there a better place to tap into oil pressure on the engine than where the current pressure switch is located? Looks like it would be tight fit to install a tee there to hold the new sender and existing switch.
TIA
Hoping the guru will chime in, as to if there's an unofficial port you can plug into instead.
examples: on the neon you can pull a bung on the head and get an oil pressure feed from there. there's also a bung on the bottom of the engine where the oil pump and filter is where you can get a pressure reading from as well. several used the latter, including me.
