me again...
Nicodemus Arceneaux
EVERY time I replace something I get a new code, replaced the downstream o2s per codes. replaced crank and cam sensors per suggestions, replaced TPS per suggestion. replaced all coils per 2 coil code, and replaced plugs(no clue how long they've been in there)
Now I'm getting a P0124,P0203,P0204 codes. it wont idle and will die if I let off the gas.
I'm this close to pushing it into a river..... please, anyone that can help? I can't afford to keep throwing parts at it.. its my only vehicle....
mduclow
Colorado Springs, CO
P0124 is the TPS sensor, check and make sure you have good contact and connection look for bad wiring and a bad connector
P0203 is injector on the # 3 cylinder, bad connector or connection, bad wiring, bad injector or ECM
P0204 is injector on cylinder # 4 same as above.
Those three things would definitely cause poor running and even the inability to stay running.
I kinda assume you already know this, but in case you didn't
