After battling an intermittent battery drain for a few years and 2 batteries, I finally found the culprit was the A/C Clutch relay contacts were occasionally sticking closed. This allowed a steady 1/2 amp draw which would completely drain the battery after a few days on sitting. Replaced the relay and all is well. Disassembled the relay out of curiosity and the contacts are quite small and were very burned up. I wonder if Chrysler puts any sort of spark arrestor across the clutch coil to prevent a voltage spike feeding back when the field collapses?
