Left side marker lights not working.
JeepINgeek
Silver Supporter
For Twain In Diana
when i turn on the headlights the marker lights on the drivers side dont work. Turn signals are fine. If i replace the fuse they work for a random amount of time until the fuse burns again...
has anyone experienced this? i really dont want to have to take it to a garage and dump tons to figure it out.
yellocoyote
NW Chicagoland
Sounds basic, but have you tried changing the bulbs to see if that takes care of it? It's a cheap option...
kb0nly
Planet Earth
Bad bulb causing the fuse to blow... I have had that happen on trailers a lot. The bulb filament burns off at one end, then when it next has power applied and you hit a bump the filament arcs and sticks completing the circuit but drawing more current than normal when lit, and the fuse blows.
Almost every time i had a problem on a trailer i would check the bulbs, tapping them one at a time until i find the intermittent one, replace it and all back to normal.
I replaced all the bulbs with LED units on the last trailer i had, no problems after that.
Clyde Frog
Central Mass
Replacing the bulbs are really easy - I believe the turn signals are just the outer, smaller bulbs which are 914 but to be safe I'd replace both bulbs (3157 and 914) just in case
JeepINgeek
Silver Supporter
For Twain In Diana
well, i replaced the rear bulb already ( it was blown ) however the system still will fuse out..
but for a few bucks ill change teh whole lot.. it cant hurt!
