Just replaced my ac compressor clutch...
Joejeeper420
NYC
And now it won't disengage even when off... The clutch just keeps spinning and spitting out cold air... Can I drive to work and home like this with the ac on low and troubleshoot the shims tomorrow? Or should I reinstall the shorter belt and bypass it in the meantime??
dude1116
Pompton Plains, NJ
Couldn't you just pull the plug on it?
Joejeeper420
NYC
It's definitely something to do with the shims and that fine clearance...
Joejeeper420
NYC
Just went outside and added more
Shims until it "slightly" grabbed... Tightened her up... Put the belt back on... Started the jeep and voila no movement in the center... Turned on AC... Boom starts spinning... Turned it off.... Click it stopped ... YAAAAAYYYYYYY!!!
Glad it is now working and for future reference the KJ compressor clutch gap has to be set properly... 0.41-0.79mm.
Joejeeper420
NYC
It was my fault for trying to do the job before I left for work... I was in a tiny bit of a rush lol.. Stepped outside at lunch... And corrected it :)
