HOW TO: Command Trac® II / MP1522 Oil Change Procedure
Diggerfreek
Colorado
Position drain pan under transfer case.
Remove drain and fill plugs and drain lubricant completely.
Install drain plug. Tighten plug to 20-34 N·m (15-25 ft. lbs.).
Remove drain pan.
Fill transfer case to bottom edge of fill plug opening with MOPAR® ATF + 4 or equivalent .
Install and tighten fill plug to 20-34 N·m (15-25 ft. lbs.).
