Is it the white aluminium filter or the black plastic one?Hi all
Is there a repair kit available for the fuel filter , washers , gaskets etc
2006 crd 2.8 Ltd
Have not actually taken the filter out of the body as yet , but seems to be a leak from the plastic body on top , when primed a little fuel comes out , hence the p0093 code I’m getting and the starting issuesIs it the white aluminium filter or the black plastic one?
Uk , will try and track one down , many thanks for helpThats the plastic body then, they are known to crack or melt and leak, the best solution is to use the earlier metal filter assembly which is actually a Racor unit, where are you? If you are in Europe they are easy to find second hand, elsewhere in the world you may have to buy a new one.
My offer stands.You can have my Gen 1 filter head if you want it for postage from 99610 US. Leave the heater disconnected and it should be fine unless it won't start in the cold. No leaks or cracks when it came off for a Gen 2.
Thanks for the offer but getting a bit colder now and it’s not the best at starting in the morning as it isMy offer stands.
I'm in the UK with a 2005 CRD and also have this same filter head. I've had a few instances of the Jeep randomly cutting out just after starting and taking a bit longer on a morning to start after been sitting overnight so suspect some air is getting in. Is the Racor filter a direct replacement for tge gen 1 filter head?I'm suprised the UK got the same filter head as the US. Probably best to get the Euro (but not UK) Racor setup from a junkyard, (in France maybe?). The Racor filters to a better standard than the Gen 1&2 setup. WWDiesel's kit just adds a secondary filter to the Gen 1&2 system.
Curiosity question... Does your turbo have a wastegate or is it the variable-vane US arrangement.
Should be, as I said above, its standard fitment on the early jeeps.I'm in the UK with a 2005 CRD and also have this same filter head. I've had a few instances of the Jeep randomly cutting out just after starting and taking a bit longer on a morning to start after been sitting overnight so suspect some air is getting in. Is the Racor filter a direct replacement for tge gen 1 filter head?
Is this a direct replacement for mine , fittings , plugs etc or do you need to “ modify “ any leads etc ?Google "Racor 245 filter", plenty of new ones for sale and available in England.
Racor 245R Spin-On Fuel Filter - Water Separator - Expresslube Ltd
<p>The Racor diesel spin-on 200 Series features a variety of compact sizes to fit in the most cramped engine compartments. All models are standard with 1/4”-18 NPTF (SAE J476) inlet and outlet fuel ports and a unitized mounting bracket. They also includewww.expresslube.co.uk
