****** Filter
bat100
I changed the ****** filter in my 05 and after putting it all back together found the O ring that goes on the filter neck. Do I need to drop the pan and put it on or will it be okay without it? Thanks
yes! you need that! the ****** probably wont even go into park and if it does, it will probably do into limp mode and not shift out of 1st gear.
DougBenn
It will run without the O ring, but it will damage the ****** if you do not replace it. Never saw it until the next day when I cleaned the drip pan. I drove 30 miles or so, but was lucky and still haven't had any problems, that was 17k miles ago.
Very poor design by Jeep and good luck trying to find that O ring at a dealer, I couldn't find it at any of the local dealers and just reused my old one even though I thought it was slightly deformed.
