EVIC forgetting settings?
Snail Farmer
Fairmont, MN
Does anyone have any ideas why the EVIC would forget settings? On occasion it will switch from standard to metric on me, and the headlamp delay doesn't want to cooperate at all anymore. Those are the only two settings that don't keep.
Porkchop
Troy Mi
My first thought would be to Check the battery and all connections.
Snail Farmer
Fairmont, MN
It still has the original battery in it. I know 9 years is old for a battery, but it still tests fine and there are no other problems. I've pulled it out and reseated the plug, and that didn't change anything. Just figured I'd see if anyone else on here has had this problem and figured it out before I spend the money on a battery just for diagnostic purposes.
Wow.....9 years old for a battery and you are in Mn. too. If it were me I would get a new battery before the real cold comes and the snow flies, "just because".
I do not know if that will fix your problem but 9 years is a real respectable length of time and that battery is ready for retirement.
LibertyFever
New Brunswick, Canada
My EVIC occasionally does the same thing, it switches from US to Metric while I'm driving so doubt it's the battery.
But mine doesn't loose anything else.
Sent from my iPad using Tapatalk
