Electrical issues 2010 liberty
Mneuk86
Hi, so I would like to see if you all have some input on the issues that I have I have a 2010 liberty Limited a while back I had to change out the ignition and since then I’ve had nothing but problems. I’m thinking being a jeep. It may just be ground issue but I figured I’d request some input.
Since I changed that ignition
my wheel pressure sensors only work 10% of the time and are intermittent
Most recently, my radio no longer stays on for that short timeframe after you shut the key off as it did previously
I’ve also recently gotten a airbag dummy light as well as my driver side electric seat, no longer operates
I know this could be a whole bunch of things, but I figured I’d give a shout
Thanks
ShowMe Cherokee
Have you scanned for OBD codes? That may give you a clue. When you say replaced the ignition, do you mean the module in the steering column that the key goes into?
For the tire pressure sensors, the batteries in them are likely dying, considering that they are 15 years old. You just have to replace them. I have had to do so in both my 2010 Liberty's. Since the airbag light is on, there will be a code for it, which could tell you where to look. It could be the clockspring, or it could be the airbag module which is under the seat, or a couple other things.
