Door Open Chime
jeepkj02
Holland, Michigan, USA
When the door is open and the key is in the ignition (engine not running) there is this annoying chime the keeps on ringing. I want to get rid of this. What fuse do I pull? What do I do? I don't have an EVIC.
When Im outside listening to the radio or something, I will stick my finger in the latch and latch it. This makes it stop so I can leave the door open and hear the radio. I always forget to unlatch and close the door, it bounces back at me. :-s
rearwindow
Pull key out 1 notch. It's something I've got used to doing being a tech. The beeping drives me nuts.
jeepkj02 said:
Thanks for that idea jeepjeepster. I will try it next time.
Just be sure you latch is twice, I forgot to tell you that. You push it up once, then again. When you barely close the door and it doesnt close all the way, thats the first latch...
