Discolored Coolant Overflow Bottle?
Now I'm worried is the inside of my block and radiator dis-colored. How do I scrub that?
- Rooo rooter -
My coolant tank is discolored as in the plastic has changed color. This isn't a sludge or buildup issue. Nothing to scrub or remove. Likely the issue is just the plastic itself so not a serious issue, just cosmetic. No worries. If you have sludge then get it professionally flushed and refilled with HOAT.
renegade 04
Albany New York
If you want to see what is in the engine block just pull the engine drain plugs like I did. Just a FYI on the drivers side you will need to loosen the starter.
