Difference between ‘07 and ‘05
scottg
Lewiston, Maine
I just picked up an ‘07 for cheap after blowing the motor in my ‘05. I noticed they changed radiators, what else is different between the years? Is the transmission the same? The ‘07 has no dipstick, does the ‘05 fit?
The 07 has a throttle body controlled by an electric motor and the computer, instead of a physical cable hooked to the gas pedal. There is no AIC on the 07 to control idle because the computer handles it. The PCV valve is now located on the drivers side rear of the cylinder head instead of on the oil fill tube. The 05 transmission dipstick will not fit the 07 transmission tube unfortunately.
