Any other battery sizes that fit a V6?
REDACTED
I wouldn't recommend putting in a different sized battery. But if you're going to, being a measuring tape to check the length and width and make sure the battery has 600 or more cca
atikovi
Suburban Washington DC
I'm not going to visit every Facebook seller and measure their battery. What I was asking is if anybody has installed another battery beside a 34 that has fit.
I have an Optima red top on mine & another battery on my parts Jeep, I'll get the part numbers off them when I go outside.
My parts jeep has a battery code 096 on it and no other information.
The red top is p/n 8002-250 rated at 815CCA
Mine are both diesel so a bit harder on batteries but I believe the battery mount is the same size.
Dont go small, the PCI bus runs just below battery voltage, a big voltage dip on startup causes all sorts of joy with random electrical issues from pissed off computers!
u2slow
BC
Sorry, have only bought the OEM/listed size battery each time.
Here's a battery size chart. See what your tray has room for.
atikovi
Had a 24 in the basement that goes right in, just a little taller. Sticker says J3 which I assume is October 2023.
