545RFE CVI values
Dr. Pluh
Hello, today i measured my CVI values with a diagnostic scanner. The values are following:
LR: 111
2C: 36
OD: 55
4C: 43
UD: 44
I couldnt find concrete info on the proper values. For example the official service manual says OD should be 30-100, other sources say 30-64, some even say 40-150
What should the actual values be and is mine ok? Thanks
Is it driving ok? The gearbox has a variable pressure system & it's own controller so it sets its own pressure.
You can boost the pressure by adding a line pressure booster or adding a resistor across the pressure sensor.
