Hello,
My Jeep is starting to regularly jump out of 1st gear on take off. There is no grinding noise, just a clean jump/clunk back to neutral. From what I have read, it can be either the Syncros or the 6sp shifter box. Most discussions point to the shifter box, as if it were syncros there would likely be some grinding of the gears when trying to select 1st gear.
I haven't been able to find a replacement Shifter box for a KJ transmission, only the Lever assembly, whoever I found a shifter box for the 6sp JK wrangler transmission. From pics of these transmissions the shifter box looks the same. Can anyone confirm if the after market shifter box in the link below will fit my 6sp KJ.
mbenzgram.com
Many Thanks,
Paul.
B&M 45195 Manual Transmission Shifter Lever Kit
mbenzgram.com
Many Thanks,
Paul.
