What is the possible source of this leak?
Clean the area up, with engine de-greaser & some rags should work ok.
Then place some cardboard below to try to determine which fluid it is firstly.
Jbergun
Chicago
If your really determined/worried open up the inspection plate on the trans its what gives access to the fly wheel and torque converter.
jja
Bulgaria
Hey I didn't realize there was an inspection plate on the 42rle. Where would that be?
The leak is minor right now. There are no drops or anything just a wet spot. However, I'd like to check out on it and the inspection plate sounds like a really good option.
jja
Bulgaria
Just to make sure I got this right. The lower half of the bell housing is removable and acts as inspection plate?
Aceofspades
Buffalo
Could use a white paper towel give it a wipe - help narrow down the fluid type
Isnt it structural though? And you must do something specific when reinstalling it? Seems I remember reading about it in the FSM
It is definitely structural but I seem to remember just following the torque specs in the FSM when I put mine back on. Don't remember anything unusual.
