What is overdrive?
Tarikleesimsek
New York
Hi guys.I kinda guess what it means but can anybody tell me the exact explanation and what it does?? Thanks guys.
JeepinJarhead03
Petersburg VA
it's a gear with a ratio over 1:1 such as 0.90:1
your rear diff has a ratio
say.. 3.73 turns of the driveshaft to 1 turn of the axle
at the transmission, your gears start out low and go up, as a very basic example let's use
1st gear 4:1 2nd gear 3:1 3rd gear 2:1 4th gear 1:1 5th gear 0.90:1
in 4th gear if your engine is turning 3000 RPM so is your drive shaft and your effective ratio of rpms to your axle would be 3.73:1
make sense?
with automotive gear ratios a lower number is a "higher" gear , works very much like a 10 speed bicycle, in gear 1 your feet may be cycling extremely fast and you're barely moving, in 10th while difficult to pedal, your wheels end up turning much faster than your feet
hyde
good explanation
in plain language:
a button to pass trucks :) manual override of 4th gear, kind of like immediate down grade to 3rd gear. or if you are towing or riding in slow traffic, keep O/D OFF you can speed up much faster, but mpg will suffer. Try it next time you are on highway doing 50, you will like the way it drives.
iamweasel
Joburg, South Africa
In addition to what the others said, the purpose of the overdrive is to drop revs while travelling on the highway - with the purpose of dropping MPG.
It's ON by default; the button on the gear stick is there to turn it OFF when you need the acceleration (torque) of a lower gear (higher revs - closer to peak torque at 4000rpm) e.g when towing or overtaking. As hyde said - it forces the gearbox to drop from 4th to 3rd
Overdrive is exactly what the name applies.Simple terms is when in overdrive the input rpm's(engine rpm's) is less then the output rpm's(trans/t-case outputs).
Your overdrive in your 42RLE is 0.69:1,so if the rear output(t-case) is spinning 1000rpms the engine rpm's are 690.
