Tattedpanda
- Joined
- Nov 10, 2021
- Messages
- 16
- Reaction score
- 1
Does anybody have a subbox mounted under any of the seats? I want to keep the trunk clear but havent found many pre-made sub boxs.
I have a Kj. I knew somebody has some exp in this area. I was looking at running this JL Audio CP108LG-W3v3. Just wasn't sure if it would fit under the seats.KJ or KK?
On the KJ there is no room for a big box except in the cargo area. Might be able to squeeze a six under each front seat ( is a six inch even considered a sub?) Back seats have no room if you need to fold your seats down do to the way the depress and slide forward when folded.
I run a pair of Skar Audio EV-10MB S4 10”(sadly now discontinued). Each has its own box and rests in the rear seat footwell. It is far from ideal as when a need to fold the back seats arise, the bench squishes them against the front seats. Then again I only haul camping gear and the occasional pug or three in the back seats. The subs have QD connections so I can just pull both subs when I need the rear seating space.
Have my amp under the driver seat, but is prone to overheating there, an issue I’ll rectify one of these days.
Am considering moving the tens in their low pro boxes to an overhead rack hung from the points where the rear grab bars are located.
Only other option is to sacrifice rear cargo space.
Would it be strong enough to hold a roof rack basket with awning?Stock rails are very light weight if that is what you are wanting to know
Depends on the awning.Would it be strong enough to hold a roof rack basket with awning?
What would you recommend? I just need something big enough to cover a group of 4.Depends on the awning.
I personally highly recommend the Slumberjack Roadhouse Tarp. Fits the KJ like it was designed for it. I have the version with the stowaway bug screen. It’s a bit tricky the first time you set it up so practice at home. You can get full details from my desert road-trip thread and the review I posted.What would you recommend? I just need something big enough to cover a group of 4.
With just awning yesWould it be strong enough to hold a roof rack basket with awning?
Wow that looks awesome!!I personally highly recommend the Slumberjack Roadhouse Tarp. Fits the KJ like it was designed for it. I have the version with the stowaway bug screen. It’s a bit tricky the first time you set it up so practice at home. You can get full details from my desert road-trip thread and the review I posted.
The only i would put up there is a cooler maybe some chairs, nothing too heavy.With just awning yes
depends on what else is up there in the basket plus what cross bars you use
On my cheapo of Amazon bars and basket I carried the tarp, 40L of fuel, ten gallons of water and that ARB double swag…off and on road. Total weight just under the max at just about 140lbs.The only i would put up there is a cooler maybe some chairs, nothing too heavy.
Wow that's really good to know, this helps me out so much.On my cheapo of Amazon bars and basket I carried the tarp, 40L of fuel, ten gallons of water and that ARB double swag…off and on road. Total weight just under the max at just about 140lbs.
Lost about 5mpg on the highway due to wind resistance….mostly because that double swag is a beast. Abnormal hail as I took a months worth of stuff for a just over two weeks trip.
The KJ is a beast!
If going for custom steel on the roof rails, best to have them gabbed locally. The one place in the US that still sells them is notoriously bad to deal with.I have the factory mopar kj under-drivers-seat sub, it’s enough for me and fits in otherwise unused space, don’t know the part number offhand, but it is a complete kit with the y-harness and everything if you get it NOS.
On the roof bars i know there were a few places that make steel factory replacements, not sure if any are still around, but it wouldn't be too hard to fab up of not. Still need to be mindful of the weight up top regardless though.
Mr. Panda,Does anybody have a subbox mounted under any of the seats? I want to keep the trunk clear but havent found many pre-made sub boxs.
