Tire iron
sblanck
Anyone here bend their stock tire iron trying to remove their tires?
Does anyone find the stock iron to be deficient.
Nope never bent it , never use it, only a 4 way
Deficient, maybe if lug nuts have been hammered on
O5berylgrnrenegade
Canada
Did my rear shocks and coil springs used a 4 way had them torqued to proper specs at the tire shop after then two weeks later did the rear brakes my brother borrowed the 4 way so used the stock iron and yes it bent even under stock torque spec lugs
jharrisliberty
Colorado
I have used my stock one plenty over the years. Still carry it as a spare. These days I just carry an electric impact to get them off and I have a breaker bar to tighten them back down.
Never used mine, I have a 4-way I use.
GunnerSchenck
I keep a 4-way in the trunk, but that's mostly just for changing other people's tires for them if I don't have a 1/2" socket for my breaker bar that fits their lugs.
I keep 15-25mm, and 1/2"-7/8" sockets in the jeeps toolbox for these events, but I've used that 4-way to get a couple people off the shoulder of the road(and out of my way :driver:)
turblediesel
memberable
Alaska
I get a 4-way for every vehicle I drive, with some black tape marking the proper socket.
Stock lug wrenches are junk and lots of shops rattle-gun them on too tight.
JasonJ
Michigan
I only use this...............
Work smarter not harder.
Same here... totally worth the cost of an electric impact JUST for tires. Granted, it works on other bolts too.
When I used to use the included tire iron, never bent it. Those of you with "stock torque" lugnuts, done by the shop... yeah, doubt it. The torque limiting adapter bars are usually no longer calibrated, if the mech uses them at all. Typically they just hit it with the impact gun on a lower setting.. figure that's good enough.
They never have trouble getting them off because their impact tools will do 700+ft lbs in reverse.. humans with a 16" tire iron dont.
I only zip them on with a impact to about 80lbs-ft then torque my lugnuts to 120lbs-ft via a calibrated torque wrench.
Same thing I do at work on every vehicle I take the wheels off.
^^yeah, the Snap-on impact gun is nice if you are using it a lot.
Getting the lugs off after a shop used a power gun putting them on can be tough. Normally that does not happen to me unless I get new tires. I do all my own 5 tire rotations the old fashioned way with arm power....LOL
Leeann
Maryland
I use a 4-way on the road.
Take them off with my pneumatic impact, put them on with it to 80 ft-lbs, the lower and torque to spec by hand.
GunnerSchenck
My impact lives at work most of the time lol don't really carry it with me for spare tire situations.. I can think of much better uses for it than to leave it in the back of my jeep.. much rather just leave my spare breaker bar I'm here
Yeah mine stay's at work too unless I go wheeling then it get's put in the Jeep.Glad I took it to MOAB since I disassembled USAFCOP's L/F end(SFA) and pressed out/in new ball joints then reassembled the L/F end with it,took 1 bar out of 4 on the battery for alot of high torque nuts and pressing duty.
dude1116
Pompton Plains, NJ
I have a Ryobi. After cracking the lugs by hand I spin off using the torque wrench. I do the opposite to get them back on.
GunnerSchenck
That's usually where mines at with battery usage too.. switch the batteries over for charging on Wednesday and Friday mornings usually. Usually at 50% around Tuesday afternoon, but that's still plenty of power to break off lugs do I just hold off on switching them till the next morning
