throttle sensor
UKKJLEE
theedgeofengland
got a intermittent throttle sensor fault ...engine management light keeps popping on garage sez its a throttle sensor ...but have no issues other than a annoying engine management light
can anyone shed any light on this problem ive only had this since it was serviced im wondering if its just a bad connection or something they disturbed when changing plugs filter etc
cheers
Common problem on Jeeps,granted more on TJ's and XJ's(mostly caused by a faulty clock spring on TJ's and XJ's).You can have a dead spot or to high/low voltage in the TPS that in most cases do not really have any driveablity issues.
Word of advice only use a actual MOPAR TPS.
