Throttle body vacuum hose/evap hose
norm6269
Mechanicsville,VA
Hello all,
Found that the plastic-like hose has cracked. It is the hose that connect just behind the throttle body and run into the purge solenoid. I would like to switch to silicone but two issues, what is the correct inside diameter for the hose and the end that plugs snuggly to the solenoid has a nozzle-like piece that isn't available on a standard line of silicone hose....am i making sense?:emotions34:
Got any room to snip a tiny bit off to take into the parts store?
Even take the whole piece off & take it in to try to match it up.
norm6269
Mechanicsville,VA
Fixed, pics below
02mazdap5
Fixed, pics below
What size is the hose. My daughters Liberty needs the same replaced. Or what is the actual part called
