The horrible pull right left problem
fastcarsspeed
SOMD
Just picked up a 02 Limited that seems to have this issues. Should I just replace the rear lower control arms and the Uppper to fix this issue or should I also be looking in other areas. It was dicey drive home 10 miles the other night with this in the rain.
Instead of throwing parts, try to find out the real issues first.
Does it pull to the right all of the time or just accelerating ?
Any other issues like vibrations, etc
fastcarsspeed
SOMD
Tom,
Already have her jacked up so I can see what is going on. The symptom is really almost like drunk driving. Hit the gas and it pulls to the right and if I let off the gas it then goes left. If I can keep even pressure on the pedal then I can control the violent nature of it. truck has 280k miles on it so it is going to need some maintenance.
Tom,
Yes then you need the new LCAs in the rear
teeje
Toledo
Just did this. Easy, was a pain though. One but suffered. Jack up by the diff and put stands on the frame. Control Arm bolts are 21mm shock is 16 and 18 I believe. And sway bar is also 18mm. When I did mine last week I replaced the nut that I got from the dealer and all four bolts for the sway bar. Good luck
Sent from my SM-N930P using Tapatalk
CzarKJ
Townsend, MA
If you are going to play the "while I am in there" game do check your upper control arm (boomerang) bushings. This would cause rear body rock but as Tom said your LCAs are making the drive inebriated.
fastcarsspeed
SOMD
I am ordering both lowers, the Upper and also a new muffler and tail pipe as there are a couple holes in the muffler. I also need to look at the rear diff as there is a ton of old oil caked on the cover so need to make sure there are no issues there.
Get MOPAR only on the rear parts, especially the tri-link.
Cheap ones last 3 months or so before the bushings are gone .
teeje
Toledo
Yes yes yes to all of that. However, I replaced my upper with an aftermarket over a year ago, must've gotten lucky.
