Tyam
Hello I have a 2004 kj with 84,000 miles on it. I was wondering would synthetic be a better choice or should I just use conventional?
Thanks
Tyam
Thanks
Tyam
False,you need a have your oil tested before going past the recommended OEM change interval.I use Amsoil European Car formula with an Amsoil EA026 (CRD) filter. Synthetic is far superior in its lubricity capability, and it allows you to go longer in between changes so you can compensate for the added cost. If youre going to go synthetic dont change your oil before 5,000 miles or your wasting your money.
Dyno and syn oil both suck, that's why I don't use either.![]()
But for the cost of testing it might as well just change it.
Great another useless oil thread.
Just use what you want and change it when the owners manual states(3k or 3 months) and you will be just fine.There is ZERO real world benefit from using synthetic anymore,and in some cases you can do more harm using synthetic then good old dyno oil.
Yes sometimes you can go longer,many times you can not a suffer accelerated engine wear doing extended drains.You dont HAVE to do anything! I know plenty of people that run analysis at 10,000 and the oil is fine. As for testing it, ok so since when is it cheaper to change 6+ quarts of oil and a filter than spending 20.00 on an analysis??
Look TK, I respect what youve done with you truck but if you really believe that there is no benefit from using synthetic oil youre not very smart! It lubricates infinitely better than dyno. The detergent packages work and last much much longer. Etc etc etc. I dont get you. As far as doing damage, that's not true. Usually the complaint some people have is that they started using synthetic and their engine started leaking. What that means is the synthetic cleaned things up so much so that the leak started. Well if that's true you needed to repair the leak in the first place!
My eyes have been opened over the last few years from learning the truth right from the horses mouth,even if it to bad mouth there own products in the process.Ive not heard that. Im going to have to look into that. Ill call Currie and ask about it.
So with engine capacities being 6+ quarts it wouldnt seem applicable in engine situations.
Thanks.
