Slight steering wheel wobble
TruLiberty
Northern Virginia, US
At like 35+ mph. Took it on the beach this week and got stuck, but got pulled out properly. Also pulled out a Titan there too with about 12 snap pulls. Think it might just need a slight alignment or has gunk in a wheel (driving to VA now otherwise id check.) what do u think? Doing the suspension in 2 months, can it wait till i get it aligned then??
Jo6pak
Left coast of WI
It's possible that you lost a wheel weight. I had the same thing happen to my old XJ, and it would only wobble at certain speeds.
I took it in to check the alignment only to find out I had a front wheel out of balance.
TruLiberty
Now that u say that i noticed one was missing and didnt think anything of it! Awesome.
TruLiberty
had it balanced and the tires rotated, but the guy said my wheel bearings are going...i think he was trying to make money off me...my best friend who's a mechanic says they only need to be changed if you can HEAR the vibrations, and the steering wheel vibrates at most speeds, not just a certain range.
hyde
I have the same problem after a tire fix & rotation.
I think my rear had the problem and when it was moved to front it became apparent. Mine only wobbles the moment I hit 55mph, below that you can barely tell. Above 70mph you can't really tell, so between 55 and 70 it is most apparent. Generally alignment won't cause wobble but out of balance will.
Time for a new mechanic.You change the hub bearings at the 1st sign of noise or play.
hyde
How much does a job like that cost anyway?
speedracerbubba
When I had my hub replaced I bought it off amazon (same price as rock auto but quicker and cheaper shipping) and had it installed for right around $100.
I would have done it myself but I kind of cut my thumb on a slicer so I wasn't able to do much at all.
TruLiberty
Well now, in that case, I'll change it when I do my suspension, seeing as I'll have everything off. That's going to be a busy weekend.
Hub Bearings
OME/Bilstein Suspension with A-Arms
Water bottle relocation
Bumper Chops
Hitch Install
Possibly EVIC install
Possibly interior accents install.
jnaut
Seattle
I disagree slightly with this. Losing a wheel weight should cause it to wobble worse the faster you go. Once a tire's out of balance, the faster you spin it, the more pronounced the effect.
TruLiberty
Thats what the main problem was, I knew that I lost it to because i was on the beach in NY and got stuck, and as i was getting unstuck i watched it fly off lol.
Jo6pak
Left coast of WI
That would be the conventional train of thought. But, my experience was that it only happened at certain speeds, like between 35-40 mph. Didn't make any sense to me either, but once the wheel weight was replaced, the problem was cured. Go Figure:shrug:
hyde
Maybe something was stuck in the tire. I just discovered that I had a screw on my front passenger side, and I don't know if it is mental or not, I don't feel the wobble as much as I did before after getting it removed/patched.
LibertyFever
New Brunswick, Canada
The bearing unit alone could cost you between $200 to $300 depending on where you shop and if you need one with an ABS sensor. It is possible to do in your driveway with the right tools.
http://www.jeepkj.com/forum/showthread.php?t=46865
When I have a wheel bearing fail I notice a loud whine when I steer left or right. For example if I turn right & I hear a whine it's the LH bearing that's failing. Also if you lift the front of your Libby and grab each tire you'll notice "play" in the bearing.
I too have had a mechanic claim that I had a bad bearing only to have a dealership mechanic disagree.
