Slave cylinder failure?
O5berylgrnrenegade
Canada
Clutch master cylinder line connection leaking
How is the clutch slave line connected to the master cylinder it is leaking and before i tear into it i would like more info on the method of line attachment to the master cylinder looks like a roll pin so im imagining a o-ring press fitting?
JeepinJarhead03
Petersburg VA
they're a sealed unit
roughly 100 bucks
they generally dont survive self-reman attempts due to the reasoning behind why they failed in the first place
O5berylgrnrenegade
Canada
I did find the sealed unit for $180cad but i also found the master and slave seperate with threaded connections and bleeder screws considering getting a line made and replacing it with seperate servicable parts opinions?
O5berylgrnrenegade
Canada
Neither the slave or the master has a bleeder screw,no way to bleed the system.
The ones i found from wagner both list a bleeder screw as well as show it in the product photo the difference is price the seperate parts are $76 and $86 plus whatever to make a line vs $180 for the complete sealed system
This the pic?
If so that is the wrong slave for a KJ.
Below pic is the correct slave for a KJ.
O5berylgrnrenegade
Canada
This the pic?
The below picture is almost identical with the exception of a bleeder on the end and the line attaches on top
O5berylgrnrenegade
Canada
I ended up ordering from rockauto as no one here in Canada seemed to have one in stock for less than $375 now just waiting to start tearing the old one out and replacing it boy i cant wait looks like a amazing time to change anyone know if the brake switch will have to be replaced? It seems the brake booster has to be loosened off from what i can see so curious if that will require removing the brake switch?
