Rear isolator pads????
Griemster1
Waterford, MI
I already have a 2" Daystar spacer in the rear. When i installed that i took the lower isulator pad off. Now my question is can i reinstal that under the daystar spacer or can i use that pad on the top or should i just go buy some upper pads from my local dealer?
Thanks.
jsc7002
Wichita/ Pittsburg, KS
I would put the lower back in, and as for the upper iso you can add 2 for a total of 3 counting the one that the KJ came with
ask (censored) he knows what you need better than anyone
(popcorn)
haha, gosh tom..
Ive never put a spacer lift in but Im curious, if he put the lower iso back in would it be possible for the whole spring and spacer to pop out since the lower iso may put the spacer above the lip on the spring perch?
KJ04
Grafton, Ohio
haha, gosh tom..
No problem, everything will be just fine.
