KidsKJ02
- Joined
- Sep 15, 2023
- Messages
- 15
- Reaction score
- 8
Hi all,
Wasn’t sure if anyone is still working on these 1st gens and just saw that some are! So I posted a thread several months ago about swapping engines from an 04 sport into an 02 limited, took forever as I only get a couple hours a week for this project and everything that could go wrong basically did but none the less the engine is in and running however, I have some serious gremlins I can’t seem to evict.
So after splitting both engines and swapping the crankshaft reluctors, and cams shaft sprockets along with all the 2002 model sensors, I’m getting random 02 sensor heater circuit errors and some times random misfire codes but not as frequent as the 02 sensor issue. It acts like a bad ground right? I found 4 grounding points two on the block for the battery and main wiring harness and the heads are grounded to the firewall. Well I’ve since removed all ground studs and wire wheeled them and sanded down locations and connectors, coated in dialectic grease and re tightened them all with no relief? Sometimes it will give one or two O2 heater circuit faults or somethings all 6. I’ve also seen random miss fire codes in #6 as well as #2 however those clear and didn’t come back? Any help or thoughts would be greatly appreciated.
The other issue I’m having with this transplant is as soon as I fired it up, it was knocking, sounded like it was from dead center of motor or coming from the timing chain cover. Sounds too aggressive to be valve train but too high pitched and intermittent to be a rod bearing, but I pulled the valve covers and inspected, not finding anything wrong, no loose rockers or failed lifters? I then replaced the timing chains, sprockets and tensioners. And it still knocked, I pulled off the torque converter acces cover and inspected the bolts there and was all good. Finally I put in some fresh oil (the stuff in it had been contaminated with coolant several times pulling off the front engine cover) well after the oil change it stopped knocking Awseome! But… after a 20 mile road test the knock comes and goes randomly sometimes faint sometimes just as loud as day 1, but will go away if I keep the rpm’s up under load for a bit? I have to mention I test drove the 04 donor and scanned it before pulling it and it ran and sounded fine with no error codes.
Once it’s all done and right, I plan on doing a full write up in here. I know others have which was super helpful in this project however it seems everyone leaves out one or two things over looked which is understandable giving all the details to this swap. Thanks for any suggestions!
(Tried to attach video of knock but apparently we can only attach photos)
