kjpilot
The boot blew out, so I removed it & cleaned out the grease to see how well this all fit together. There is 2.4mm of clearance between the axle & the cup.
The joint itself is shoved deep in the cup. & I think that is the only "bad" deal going on with the 4" lift. When installing the clevis to the LCA, I had to use a ratcheting tow strap to pull the clevis in toward the body to get the bolt holes to line up. As the LCAs drop, the mounting points pull in toward the body. When installing the clevis to the LCA, I had to use a ratcheting tow strap to pull the clevis in toward the body to get the bolt holes to line up. I thought I was fighting the bushings at the top of the tower, but I see now that I was fighting the joint too.
I'm going to do a 1" cradle drop, which will allow the LCAs to pivot up & the clevis mount point out & I hope that solves the problem. I'll contact Marlin about this too. Enjoy!
